Mr Cannondale
Vilken 29er?? ni väljer
Tänkte testa en 29er för att bilda mig en egen uppfattning om hur 29er är i jämförelse med FS/HT 26 mn har ingen koll alls på dessa cyklar så jag tänkte att ni skulle få rösta fram vilken modell som e bäst:-) Prismässigt ligger dom hyfsat lika, Trek/fisher e billigast strax under 30k sen s-works o cannondale kostar några tusen till.
1: Cannondale Flash carbon 1
2: Trek Fisher superfly elite
3: Specialized s-works 29er
rame Flash 29'er, BallisTec Hi-MOD Carbon, SAVE, BB30 1.5 Si head tube
Lefty 29'er Carbon XLR, 90 mm, OPI, Solo Air
Rims Stan's ZTR Arch 29'er 32 hole
Hubs Lefty SL front, DT Swiss 240S rear
Spokes DT Swiss Aerospeed
Tires Schwalbe Racing Ralph PaceStar, 2.25" tubeless ready
Pedals n/a
Crank Cannondale Hollowgram SL, 39/26 w/XX chainrings
BottomBracket Cannondale BB30
Chain KMC X10SL, 10-speed
Rear Cogs Shimano XT, 11-36, 10-speed
Front Derailleur SRAM X9
Rear Derailleur SRAM X0
Shifters SRAM X0
Handlebars Truvativ Stylo World Cup Flat 680 mm
Stem Cannondale OPI adjustable, -5 degree, 31.8
Headset HeadShok
Brakes Avid Elixir X0 Carbon 185/160 mm
Brakelevers Avid Elixir XO Carbon
Fi'z:k Tundra2 Mg
Seat Post Flash Carbon, 27.2 x 420 mm w/SAVE
Grips Cannondale foam locking grips
Ram Monocoque carbon, G2 29" Geometry
Gaffel Fox F29 RLC w/E2 steerer, custom G2 Geometry, 51mm offset crown, 100mm travel
Hjul Bontrager Race X Lite FCC Scandium Disc 29, 28 hole
Däck Bontrager 29-2, Team Issue, 29x2.1"
Växlar SRAM X.0, 10 speed
Fram SRAM X.0
Bak SRAM X.0
VevarmarSRAM X.0, 39/26
Kassett SRAM PG-1070 12-36, 10 speed
Komponenter
Sadel Bontrager Evoke 3, titanium rails
stolpe Bontrager Race X Lite ACC, 27.2mm, 5mm offset
Styre Bontrager Race X Lite Carbon Big Sweep, 12 degree sweep
stam Bontrager Race X Lite, 31.8mm
Styrlager Cane Creek IS-2/Z3, 1.5"
Bromsar Avid XO hydraulic disc brakes, 6-bolt; G3 160mm rotors
am:FACT 11m carbon, 29" geometry, FACT IS construction, tapered HT, carbon PF-30 BB, hollow carbon dropouts, replaceable alloy derailleur hanger
Gaffel: Custom Specialized/RockShox Reba S29 with Brain, 1 1/2-1 1/8" carbon steerer/crown, RockShox Reba lower, Brain Fade, external rebound adj., 90mm travel
Växlar: SRAM XX, 10-speed, 11-36t / SRAM XX, 10-speed, carbon trigger, Match Maker clamp
Bromsar: Custom Avid XX R World Cup, tool-less reach adj., alloy backed semi-metallic pads, magnesium caliper and lever body w/ carbon blade, ti hardware, 160mm rotor
Hjul: Roval Control SL 29, carbon disc, 26mm, 32h
Storlek: 15.5" 17.5" 19" 21"
Färg: Carbon/White/Red
Övrigt: Sadel - Specialized BG Phenom Expert, 143mm width / Däck - -Works Renegade, 29x1.95"
Pedaler medföljer ej.
Pedals n/a
Shifters SRAM X0
Headset HeadShok
Fi'z:k Tundra2 Mg
Fram SRAM X.0
Bak SRAM X.0
Komponenter
