scott scale 50...
...Någon som har något att säga om denna cykel, till en rookie?
Weight
12.4 kg
27.3 lbs
Frame Scott Scale Alloy 7005 DB hydrafrom monocoque tubes V dropout design Delta SST bridge Integ. HT BOX chainstay bridge
Fork Rock Show Tora 302 Coil Spring keyturn lockout reb. Adj. 100mm travel
Headset Ritchey OE 1 1/8" semi integrated 44/50mm
Derailleur (Rear)Shimano XT RD-M761 27 Speed
Derailleur (Front)Shimano Deore FC-M530 34.9mm
Shifters Shimano Deore SL-M511 Rapidfire plus w/gear indicator
Brake Levers Avid Juicy 3
Brakes Avid Juicy 3 160 F & R mm Rotor
Crankset Shimano LX FC-M580 hollowtech 2 44Ax32Ax22A T
BB-Set Shimano Cartridge 68mm shell
Handlebar Scott X-Rod 600mm/ 5° bend
H'stem Scott Comp 4 bolt 1-1/8" /6°angle
Pedals Shimano PD-M505 Clipless pedal
Seatpost Scott Comp 31.6mm
Seat Scott Racing
Hub (Front)Scott Disc Comp
Hub (Rear)Shimano FH-M475 Disc
Chain Shimano CN-HG53
Cassette Shimano CS-HG50-9 11-32 T
Spokes DT Swiss Champion Black 1.8mm
Rims
Alex TD- 24 Disc 32H Black
Tires Scott OXYD 26 x 2.0 60TPI Kevlar Bead //Sasa
Weight
12.4 kg
27.3 lbs
Seat Scott Racing
Rims
