erolwi
Decemberutmaningen - Lär dig bunnyhoppa för en hundring!
Sjuk, uttråkad och råkade hamna på CatGPT. Frågan blev naturligtvis hur man bunnyhoppar. Inte alls dåligt svar:
Bunnyhopping is a technique used in cycling to lift the front and rear wheels off the ground simultaneously. Here are the basic steps to bunnyhop a bicycle:
- Begin by riding towards an obstacle, such as a curb or a small obstacle on the ground.
- As you approach the obstacle, begin to shift your weight back on the bike while keeping your arms straight and your feet level.
- Quickly push down on the pedals while pulling up on the handlebars to lift the front wheel off the ground. This should be done in one fluid motion.
- As the front wheel reaches the peak of its lift, quickly tuck your knees into your chest and use your arms to pull the rear wheel off the ground.
- Once both wheels are off the ground, extend your legs and push the bike forward to land on the other side of the obstacle.
- Practice this technique slowly at first until you become comfortable with it, then gradually increase your speed and try it on larger obstacles.
