Sambal Oelek
Garmin Edge 1030
Då har den äntligen kommit, nya toppmodellen.
En hel del små förbättringar, ändringar. Bättre Strava-synk och ny design på enheten.
Känner mig inte jättesugen på att uppgradera från min 1000.
https://www.dcrainmaker.com/2017/08/garmin-edge-1030-in-depth-review.html
Lista på nyheter:
– Totally revamped main user dashboard: This is pretty apparent from pretty much any photo you see here.
– New FirstBeat Recovery and Training Status metrics: We saw these introduced on FR935/Fenix 5 earlier this year, they mirror the same here.
– New External Battery Pack Option: You can now attach a secondary battery pack to the bottom using a locking mechanism.
– Longer battery life: Claimed at up to 20 hours internally, and then you can stack on another 24 hours with the battery pack.
– Trendline popularity routing: When creating routes, it’ll leverage all the data from Garmin Connect to find the best cycling routes across road, mountain, and gravel categories, meaning that it’s going to leverage where people actually ride.
– Support for Bluetooth Smart sensors: Like the Fenix 5 and FR935, you can now pair to Bluetooth Smart heart rate straps, speed, cadence, and power meter sensors.
– New Garmin Connect Mobile Course Creator: You’ll see improvements here in conjunction with the new Garmin Connect Mobile (GCM) that allows route creation more easily from the phone.
– New Garmin Connect Mobile Workout Creator: As part of the new GCM release, you can now create structured workouts on the phone (finally!).
– Rider to Rider Messaging: You can send/receive canned messages to other Edge 1030 users in your friends list.
– Real-time Strava Segment listings: The unit will now use your phone to show you actual Strava segments nearby as you ride along (not just pre-loaded ones), along with real-time data on those segments.
– New Strava Routes Connect IQ App (pre-loaded): This app allows you to pull your saved Strava Routes directly to your Edge 1030 (this will be released for all Edge Connect IQ compatible units).
– TrainingPeaks & Best Bike Split Connect IQ apps pre-loaded: These will automatically be on your unit to begin with. Simple as that.
– Updated Workout Functionality: Software now lets you restart a structured workout step, such as if outside and stuck at a red light.
– Display handles rain a lot better: The display is far better than before in wet conditions. Check out my video on this below.
– New protected microSD card slot: While it comes pre-loaded with maps, you can add more maps on microSD card and this new slot design is much more waterproof/weatherproof
– New out-front mount: Places unit level with handlebars, instead of above it.
– Slightly uglier white external case design: Just my two cents. I like the black look of the Edge 1000.
Lista på nyheter:
