Hållbarhet tubeless gucka i flaska?
Hur länge håller t.ex Caffélatex för er?
Trots att jag förvarat mitt "rätt" så verkar den jag öppnade för ett år sedan inte riktigt vara som ny. Den har fått lite klumpar.
Enligt hemsidan:
Caffélatex will last 2 years after the bottle is first open, as long as the bottle is closed properly and stored away from direct sunlight, and the storage temperature is within the range stated above.
To check if a bottle of Caffélatex is still good, even after a long time since first opening it:
Enligt hemsidan:
- the liquid should have a homogeneous viscosity (no solid chunks or evident separation between lighter and denser liquid);
- 10-second test: wet thumb and index in liquid Caffélatex, press it between the two fingers for ten seconds then release: if it starts to create a solid layer, it’s still functioning properly.
