Hasse E7000
Shimano E-Tube
Det ska enligt manualen gå att ändra assist start mellan Quick till Mild i E-Tube. Men jag kommer inte åt att ändra på just dessa inställningar
Det står i manualen : Assist patterns cannot be set in this application. ???? vilken applikation ska man då använda? det beskriver sen i manualen att man kan ändra just assist start mellan Quick till Mild.
Assist settings
You can configure the various settings related to the assist function of E-BIKE.
For details on the assist settings, see the help.
Assist settings
- Tap the function to configure on the customization top screen.
- Configure the various settings.
Assist patterns cannot be set in this application.???????????
Riding characteristic- Select the type of riding characteristics for the assist functions.
- The BOOST, TRAIL, and ECO setting can only be changed when “CUSTOMIZE” has been selected in (1).
Selecting/creating an assist pattern (assist characteristic/upper limit torque/assist start)
- Select profile 1 or profile 2.
After exiting the application, assist is performed with the profile selected here. - Select the mode.
- Select the various setting values.
The range that can be selected differs for each setting value.
Note:
- The white circle on the slider indicates the initial value.
- The setting values of other modes are displayed on the top of the scale (ECO in light blue, TRAIL in green, and BOOST in yellow).
- Tap “APPLY”.
The settings are reflected to the unit.
