[Kalender] Randonnée 200 km - Södertälje 2022-10-01
what kind of pace are people riding this at? I did a 200km from uppsala last november and everyone seemed to race from the start. I'm just wondering if I should plan on being alone for this ride as well or if there might be different groups that form during the ride.
Really hard to say. Depends so much on the people that decide to participate.
That said, I think one should always be prepared to be able to ride the entire loop alone, should it be necessary. But, of course, one hopes to get some company. At least that is my motivation for doing these kinds of rides. If I know that I would have to ride alone, I'd rather start from my own door and avoid the transportation to the start/from the finish.
All brevets (reces) are unsupported. In that case there are no speed groups either. I've done the sportgrus race three times and there have been different groups of riders doing this in different speeds at all times. From top speed gravel racers to those in chatting mode all the way too.
I'm planning on riding and last time I did it in aprox 10h with stops.
your chatting mode is like me pushing 100%
I'm hoping to be able to participate, so something around 20kph or 11h is OK by me. Hoping there is other slow going riders to join up with or ride by myself which is fine too.
Vad är rekommenderad däckstorlek på denna?
Jag har kört 35 mm grusdäck. Någon körde 25mm lvg-däck men det var nog i klenaste laget. Någon annan kör fort på 2,1 27,5”-däck. Trenden med bredast däck vinner har väl avtagit när fler kör gravelracers som inte tar så mycket däck. Mest riktigt fingrus så…
Skulle vilja köra med 30 bak och 28mm fram. Hur svårt är det gruset där? Är det "lätt" (mest platt, inte så mycket stenar och rötter) eller lämpligare för MTB?
Det är mest fingrus även om det finns inslag av lite grövre varianter längs banan men det är också rätt mycket asfalt på denna runda. Jag skulle gissa att för min del hade 32mm GP5000 varit det snabbaste alternativet men har kört med 38mm snabbgraveldäck och då får man god komfort och slipper hålla stenkoll på underlaget hela tiden.
Rikard körde 21mm slicks på en retroracer för några år sedan och det gick bevisligen fint även om han tyckte det blev i skakigaste laget mot slutet :)
Jag tänkte iallafall ställa mig på startlinjen och det vore kul med sällskap även här. Hamburgaren i Kjula var en höjdare förra året! Repris på den.
Hello,
I will join this Randonneé.
Can someone share the "Vägnot" for the track provided in the webpage?
I have checked some vägnoter of a couple 200kms rides in Södertälje but they do not seem to match the track for 2022/10/01.
Thank you.
Best regards,
Raúl.
There are at least three different 200 km courses starting/finishing in Södertälje, so it is not surprising that you have found some notes that do not match the course for this ride.
Regarding the correct notes, I guess @Grimpeur or @Grimpeuse could perhaps help, as they are the ones responsible for this ride.
Hello,
Thank you.
Best regards,
Raúl.
We are glad that you will join this ride.
There are unfortunately no available route sheet for this ride. Main reason for this is that the course is mainly on gravel roads in the forrest. These roads lack roadsigns. The only way to follow it is either GPS or follow the back of another rider. The ride is normally quite popular so if you have good legs that should be possible.
No problem! GPS file is enough for me, thanks for the reply!
Vi var förbi Kjula i helgen och möttes av nedbrunnen pizzeria omgiven av polistejp. Tips på alternativt matställe tages tacksamt emot. Jag något svagt minne att någon här på forumet nämnt något om hamburgeri, men var låg det? Stämpling går alltid att lösa via foto av nedbrunnen pizzeria...
Är nedbrunna pizzerior så olika varandra att de är säkra indikatorer på att cyklisterna verkligen varit på rätt plats? Får bara hoppas att ingen pizzeria i närheten av rutten brinner ner då loppet pågår. ?
But is there a list of controls? Wanted to plan a route in advance.
    510.1 KB · Besök: 129
Kan meddela att uteserveringen på Kjula Pizzeria klarade sig från branden och funkar för förtäring av egen matsäck.
Annars ligger Burgeriet ca 3km därifrån, med två andra restauranger vägg i vägg.
RIP Kjula Pizzeria☹️
Standard för Randonneur Stockholms lopp är 48 timmar innan start. Sen kan arrangörerna göra avsteg om de vill, typiskt i så fall att korta ner intervallet mellan anmälningsstopp och start.
När jag just nu tittar i inställningarna för loppet står det att anmälan kommer att stänga 24 timmar innan start. Med mindre än att @Grimpeur eller @Grimpeuse bekräftar att det verkligen är detta som kommer att gälla så skulle jag tillsvidare utgå från att det är 48 timmar som gäller.
Anmäld men är fortfarande lite småkrasslig efter förkylning. Har dessutom tränat jävligt lite och dåligt de sista veckorna. Kommer bli kul mao!
Blir inget för mig tyvärr. Sjukt taggad, men än mer taggad på annat oxå som får gå före denna gång tyvärr.
Hade gärna vart med om det inte vore för att graveln är på service, och det känns sådär att köra med 25mm. Kommer att köra en runda med en polare i samma trakter på lördag dock, så vi kanske ses ändå ?
Blir randopremiär för mig. Är det vanliga att man har med sig lite färdkost men att man käkar/fikar/fyller på på stoppen? Antar att en gravel är lämpligt val för rundan? Ska bli kul!
det är väldigt olika
några kör hela rundan med medhavd mat.
Många köper något vid stämplingarna.
Ska man köra i en klunga får man anpassa sig lite efter klungan
jag sitter alltid och mumsar på saker, vingummin, choklad macka, kakor, pingvinstång under tiden. ngt ska man ju syssla med medans man njuter av naturen
