[Köpråd] DH-frågor Glory eller Session?
Jag behöver lite assistans. Tänkte köpa mig en DH-rigg. Har lyckats få ner kandidaterna till två.
Det här blir min första renodlade DH-cykel, har tidigare åkt utförs med en överbyggd Reign. Men nu vill jag testa en riktig hoj, med längre slag och, framförallt, rätt vinklar.
Dessa två funderar jag på.
Giant Glory 1
Spec
size S,M,L
color Black/Red
frame ALUXX SL-Grade Aluminum, 8" Maestro Suspension
fork RockShox BoXXer Team, 203mm
shock RockShox Vivid 4.1
handlebar Truvativ Holzfeller, low rise
stem Truvativ Holzfeller, Direct Mount
seatpost Giant Connect, 30.9
saddle
Fi'zi:k Tundra w/ Manganese rails
pedals Not Included
shifters SRAM X7, rear
front derailleur MRP G2 guide
rear derailleur Sram X9
brakes Avid Elixir R Hydraulic disc 8" rotors
levers Avid Elixir R Hydraulic disc
cassette SRAM PG970DH 9speed 11-26
chain Shimano HG-93
cranks Race Face Atlas 38T
BB Race Face X-type
rims Sun EQ31 disc
hubs F. Giant tracker 20mm R. DT Swiss 340 12x150mm
spokes DT Swiss Competition Butted 14/15g
tires Michelin Hot S, 26x2.5
Trek Session 8
Sizes 15.25, 17.5, 19.5"
Frame Alpha Red Aluminum w/ABP, Full Floater, alloy EVO Link, E2 tapered head tube, oversized pivot bearings, replaceable derailleur hanger, ISCG, 203mm travel
Front Suspension RockShox Boxxer Race w/coil spring (15.25/17.5" red; 19.5" blue), rebound, low speed compression, internal preload, Motion Control IS, 1 1/8" steerer, 20mm Maxle DH, 200mm
Rear Suspension Fox DHX 4.0, custom "DH race tuned" w/air adjust bottom/bottom out, rebound; 8.75x2.75" (15.25" 400lb; 17.5" 450lb; 19.5" 500lb spring)
Wheels
Wheels Bontrager Big Earl Disc wheel system, 6 bolt, tubeless ready
Tires Maxxis Minion DHF, 26x2.5"
Drivetrain
Shifters SRAM X.7 trigger
Front Derailleur n/a
Rear Derailleur SRAM X.9
Crank Race Face Respond DH, 38T
Cassette SRAM PG970 12-26, 9 speed
Pedals Wellgo B087B
Components
Saddle Bontrager Race
Seat Post Bontrager Rhythm, 31.6mm, 5mm offset
Handlebars Bontrager Big Earl, 25mm rise
Stem Bontrager Big Earl, 10 degree
Headset FSA NO.57E, E2, ACB sealed bearings
Brakeset Avid Elixir R, hydraulic disc
Frame Size
15.25 in S
17.5 in M
19.5 in L
A Head Angle 65.0° 65.0° 65.0°
B Seat Angle 58.0° 58.0° 58.0°
C Effective Top Tube 57.322.6 59.623.5 62.224.5
D Chainstay 44.017.3 44.017.3 44.017.3
E Bottom Bracket 36.314.3 36.314.3 36.314.3
F Offset 4.51.8 4.51.8 4.51.8
G Wheelbase 114.545.1 116.846.0 119.347.0
Actual Frame Size 38.715.2 41.916.5 45.718.0
Trail 11.04.3 11.04.3 11.04.3
Standover 83.032.7 83.032.7 83.032.7
Frame Reach 36.714.4 39.015.4 41.516.3
Frame Stack 59.823.5 59.823.5 59.823.5
Specen är ju rätt lika(vad jag kan se), och dom kostar ungefär lika.
Eftersom jag är noob på det här med DH-cyklar, behöver jag hjälp. Är det något ni ser som är till fördel för någon av dessa två? Eller är det skitsamma, kommer jag inte att känna nån skillnad? Välj den som är snyggast, typ.
Jag kommer bara att cykla på den för skoj, inget tävlande. Hammarbybacken, Gesunda och Åre. Jag är 171 cm och väger 70 kg. Har cyklat mycket i skogen, och en del utförs.
Tänker mig att jag ska ha small på båda.
/Mattias
Giant Glory 1
Spec
size S,M,L
color Black/Red
saddle
pedals Not Included
chain Shimano HG-93
BB Race Face X-type
rims Sun EQ31 disc
Trek Session 8
Wheels
Drivetrain
Pedals Wellgo B087B
Components
Frame Size
15.25 in S
17.5 in M
19.5 in L
/Mattias
