This is Sam here from Singular - I did a web page translation of this thread and hope I can offer a few answers and clear a couple of things up. Sorry for the English response, but I suppose your English is vastly better than my Swedish :) If not use
Systran like I did.
First I guess it's best to to clear some things up...
For the first production run the SS will be in blue, the geared version in a reddish coppery colour, it's nice. There will be some better photos going up on the website shortly which will give a closer reflection of the true colours.
Yes, the SS will come with a Phil Wood EBB, and both versions will come with a seat clamp - however these won't be Salsas as Phil metioned - but some quite nice little silver units nonetheless. If Phil wants to offer them with Salsas though he's more than welcome ;)
So to the more general points which have come up on the design and sizing.
It seems a big question is 'why no small?'. Well, I guess it kind of depends on your definition of small. The smallest frame has a 23.3" (592mm) effective top tube - which is only slightly longer than the 'small' On-One Inbred, and the 'smalls' of a number of other manufacturers. Anyway so it is fairly small. However that is as small as they come and as small as I was prepared to do for a production bike. I like bikes that handle nice and fast - so that's what I wanted to design. It's impossible to design a frame which will handle as I like with a suspension fork (with the current range of fork offsets available - I'm interested to see the new Bontrager influenced Manitous) without having toe overlap problems when running normal length cranks. If the Manitou or other forks become available with more offset I will look into designing smaller frames around them - however you then have to keep in mind the front end can get too high. Basically I think that 29" wheels make most sense for taller people. If you are under about 5'7" you should feel quite proportionate and happy on 26" wheels. If enough people want a Singular with 26" wheels in small sizes I'll happily design them.
I use a set screw type Phil Wood EBB to tension the chain on the SS without influencing the disc brake. This does of course influence seat angle, bb height, and effective chainstay length. But you can look at this as a benefit also, as it gives you the possibility of varying those dimensions if the stock geometry is not quite to your liking. For instance if I lived in Stockholm and rode your super rock conditions all the time I'd position the EBB towards the top of its rotation to give an extra 2cm or so of crank clearance. I found an EBB to be the most elegant solution to the problem of a disc braked SS. I chose the Phil Wood set screw EBB for the frames because it's proven to be the most reliable and problem free kind.
Sorry for the ramble - but once you get me started it's tough to stop. If anyone has any more questions feel free to send me a mail or post on here - I'll check this thread again - though as you know I'm not a regular on these boards :)
Thanks for all you positive comments and your interest.
All the best,
Sam
Singular Cycles
