Sram GXP 24/22 pressfit
I have a issue with the crankset it doesn’t spin.
Roadbike BB86 pressfit, bearings are good.
it spins okay before I mount left pedal arm NDS.
Then I mounted the left arm and start to tighten it to just 24 N half the recommended. it will not spin. Not like a Shimano that turns around for some turns.
The wawe washer should be on the DS but some forums says it only for MTB use.
have test with and without. Same resul.
any suggestions or should the crankset not spin so easily on SRAM GXP?
