Sram GXP 24/22 pressfit
Gramdk
I have a issue with the crankset it doesn’t spin.
Roadbike BB86 pressfit, bearings are good.
it spins okay before I mount left pedal arm NDS.
Then I mounted the left arm and start to tighten it to just 24 N half the recommended. it will not spin. Not like a Shimano that turns around for some turns.
The wawe washer should be on the DS but some forums says it only for MTB use.
have test with and without. Same resul.
any suggestions or should the crankset not spin so easily on SRAM GXP?
If you remove all spacers on the drive side before tightening nds, does it spinn freely then?
Have you changed anything? Did it use to work?
New setup on a frame I bought.
The BB was installed. Looks right installed to my knowledge.
Just figured it out. The rubber sealing on the left site I had mounted wrong. Small difference on the engagement. )-:
Thx the thought and comments.
Lite bilder kan vara bra.
Mät bredden på lagret när det är monterat?
Det låter som axeln är för kort i förhållande till lagrets bredd i alla fall.
