| Trek | FX 1 Disc
Stagger | FX 2 Disc
Stagger | FX 2 Disc Equipped
Stagger |
| Trek Bicycle Store | FX 1 Disc
Stagger | FX 2 Disc | FX 2 Disc Equipped
Stagger |
| RRP SEK | 6 999 | 8 199 | 10 599 |
| REA | | | |
| Växlar | 2x8 | 2x9 | 2x9 |
| Bakväxel | Shimano Altus M310 | Shimano Altus M2000, lång arm | Shimano Altus M2000, lång arm |
| Framväxel | Shimano Tourney TY710, 34,9 mm klämma, Top Swing, Dual Pull | Shimano Acera T3000, 34,9 mm klämma, Top Swing, Dual Pull | Shimano Acera T3000, 34,9 mm klämma, Top Swing, Dual Pull |
| Växelreglage | Shimano EF500, 8-delad | Shimano Altus M2010 | Shimano Altus M2010 |
| Kasett | Shimano CS-HG31-8 11-32T | Shimano HG200-9 11-36T | Shimano HG200-9 11-36T |
| Vevparti | Smitt aluminium, 46/30, kedjeskydd, 170 mm längd | Smitt aluminium, 46/30, kedjeskydd, 170 mm längd | Smitt aluminium, 46/30, kedjeskydd, 170 mm längd |
| Maximal storlek på kedjekrans | 1x: 42T, 2x/3x: 48T | 1x: 42T, 2x/3x: 48T | 1x: 42T, 2x/3x: 48T |
| Vevlager | Kapslat lager, 68 mm | Kapslat lager, 68 mm | Kapslat lager, 68 mm |
| Kedja | KMC Z8.3 | KMC X9 | KMC X9 |
| Pedal | Wellgo nylonpedal | Bontrager City-pedaler | Bontrager City-pedaler/Wellgo C157 |
| Bromsar | Tektro MD-U310 mekanisk skivbroms, Flat Mount, 160/160mm | Tektro HD-R280 hydraulisk skivbroms, Flat Mount, 160/160mm | Tektro HD-R280 hydraulisk skivbroms, Flat Mount, 160/160mm |
| Bromstyp | Mekanisk | Hydraulisk | Hydraulisk |
| Bromsfäste | Flat Mount | Flat Mount | Flat Mount |
| Bromsskivor mm | 160/160 | 160/160 | 160/160 |
| Däck | Bontrager H2 Comp | Bontrager H2 Comp | Bontrager H2 Comp 32/Bontrager H2 Hard-Case Lite 35 mm |
| Däckstorlek | 700x35 mm | 700x35 mm | 700x32 mm/700x35 mm |
| Däcksutrymme | 700x38 mm | 700x38 mm | 700x38 mm |
| Däcksutrymme med skärm | 700x35 mm | 700x35 mm | 700x35 mm |
| Fälgar | Bontrager Connection, aluminium, dubbel botten, 32-håls, Schrader-ventil | Bontrager Connection, dubbel botten, 32-håls, 20 mm bredd, Schrader-ventil | Bontrager Connection, dubbel botten, 32-håls, 20 mm bredd, Schrader-ventil |
| Framnav | Formula DC-20, aluminium, 6-bults, 5 x 100 mm QR | Formula DC-20, aluminium, 6-bults, 5 x 100 mm QR | Formula DC-20, aluminium, 6-bults, 5 x 100 mm QR |
| Baknav | Formula DC-22, aluminium, 6-bults, Shimano 8/9/10-delad frikrans, 135 x 5 mm QR | Formula DC-22, aluminium, 6-bults, Shimano 8/9/10-delad frikrans, 135 x 5 mm QR | Formula DC-22, aluminium, 6-bults, Shimano 8/9/10-delad frikrans, 135 x 5 mm QR |
| Sadel | Bontrager Sport | Bontrager Sport | Bontrager Sport |
| Sadelstolpe | Bontrager aluminium, 27,2 mm, 12 mm offset, 330 mm längd | Bontrager aluminium, 27,2 mm, 12 mm offset, 330 mm längd | Bontrager aluminium, 27,2 mm, 12 mm offset, 330 mm längd |
| Styre | Bontrager Riser, stål, 25,4 mm, 30 mm rise, 600 mm bredd XS, S, M & L/620 mm XL & XXL | Bontrager aluminium, 31,8 mm, 15 mm rise, 600 mm bredd XS, S & M/620 mm L, XL & XXL | Bontrager aluminium, 31,8 mm, 15 mm rise, 600 mm bredd S & M/660 L & XL |
| Handtag | Bontrager Satellite | Bontrager Satellite | Bontrager Satellite |
| Styrstam | Bontrager aluminium, 25,4 mm klämma, 10°, 90 mm S, M & L/110 mm L, XL & XXL | Bontrager Comp, 31,8 mm, Blendr-teknikkompatibel, 7°, 90 mm XS, S & M/100 mm L, XL & XXL | Bontrager Comp, 31,8 mm, Blendr-teknikkompatibel, 7°, 90 mm längd S & M/100 mm L & XL |
| Styrlager | 1 1/8" stål ogängat | 1 1/8" stål ogängat | 1 1/8" stål ogängat |
| Ram | Alpha Gold Aluminum, DuoTrap S-kompatibel, invändig vajerdragning, Flat Mount-skivbroms, monteringsfästen för pakethållare och skärmar, 135 x 5 QR | Alpha Gold Aluminum, DuoTrap S-kompatibel, invändig vajerdragning, Flat Mount-skivbroms, monteringsfästen för pakethållare och skärmar, 135 x 5 QR | Alpha Gold Aluminum, DuoTrap S-kompatibel, invändig vajerdragning, Flat Mount-skivbroms, monteringsfästen för pakethållare och skärmar, 135 x 5 QR |
| Gaffel | FX Steel, Flat Mount-skivbroms, pakethållarfästen, 405 mm axel till krona, ThruSkew 5 mm QR | FX aluminium, Flat Mount-skivbroms, pakethållarfästen, 405 mm axel till krona, ThruSkew 5 mm QR | FX aluminium, Flat Mount-skivbroms, pakethållarfästen, 405 mm axel till krona, ThruSkew 5 mm QR |
| Vikt kg | 12,68 M | 11,73 M | 13,2 L |
| Maxvikt kg | 136 | 136 | 136 |
