Sjysst tillverkade cykelprylar
Status
Hope vinner reservdelsmatchen helt klart.
Orange, Fairlight.
Hur var det nu med Fairlights ramar? De flyttade väl produktionen eller minns jag fel...? Byggs ihop i UK och förr byggdes ramarna "i Europa", men mitt minne sviker mig kring vad som hände för ett par år sedan. Någon med koll?
Strael, faran och secan görs iTaiwan numera
Holt "i eu"
Ingen lista över lokalbryggda cyklar är komplett utan weldpornstjärnorna på Nicolai och cnc-kungarna på pole.
Good on you kan ge en fingervisning för kläder.
Jäklar vilken fluffig sida, fick känslan av köpta märkningar, när marknaden ska granska sig själv blir det lätt ihåligt. Fick mig att tänka att regnskogsalliansens märkning ser seriös ut.
"How accurate is the Good On You rating system?
Good On You is a great sustainability app to use, but it has many issues. Its rating system isn't as exhaustive as it should be, and many gaps exist in each brand evaluation.
The Good On You review of popular fashion brands is oftentimes very subjective. While they do a good job pointing out sustainability issues, the grades from 1 to 5 aren't the best representation of a brand's effort to become better.
The Good On You rating system can only evaluate easily accessible and publicly available information, which arguably represents one of its biggest flaws.
A grade from 1 to 5 is also quite limited. Many fashion brands receive the same grade, even though they aren't equally sustainable.
And, since the Good On You app covers both brands marketed as ethical and conventional brands with the same rating system, this leads consumers to believe that some fast fashion brands are as sustainable as eco-conscious brands and vice-versa.
Good On You is a pretty good resource overall, especially for someone new to sustainable fashion, but not nearly comprehensive enough. Many apparel brands appear on the app/rating website as eco-friendly when they aren't in reality.
The Good On You rating system isn't very accurate, but it's a good start to discover new brands you might want to try out. Worse, the editors often make assumptions.
They use a standard template with a similar approach for every brand. It's based on some automatically generated text that doesn't reflect precisely a brand's sustainability efforts.
Good On You doesn't do a great job at verifying information either. It seems to base its ratings mainly on each brand’s website with little care for truthfulness or accuracy." https://www.panaprium.com/blogs/i/good-on-you
Som sagt, en fingervisning.
Okej. Jag kommer inte kunna fylla listan själv så vi kör lite teman.
Idag kör vi sjyssta ramar. MTB, lvg, övriga.
Vi har två leverantörer i listan men skriv fler så fyller jag i listan sen
Hej.. Sarto, Benotti, Festka, TIME, Mercian, Duratec, den nya fabriken i Portugal ( Focus ), Carbotec ( Basso ), Bianchis nya fabrik i Italien, plus en herrans massa småfirmor typ enmans överallt.... mvh borano20
En hel del fel här, kan jag se efter att ha besökt fabrikerna. Många saker tillverkas inte där man vill ge sken av. Väldigt många parametrar att ta hänsyn till om produktionen är bra.
Då är det bara rätta felen :)
Jag önskar att jag kunde. Men man skriver på en massa papper hit och dit, så jag får inte.
Tror att man kan få en del svar genom att Googla. Genom åren har jag ibland snubblat över hur det ligger till av en ren slump. Gissar att andra som besökt fabriker skrivit om det i internationella cykelforum. Testa att söka där.
Chromag är ändå värt att ta med då de är en stor tillverkare av prylar som ändå har lokalt tillverkade ramar.
Mycket high end och boutique finns ju som sagt. Det är kanske snarare vanliga prylar och inom vissa segment som jag tror blir svårt.
Fälgar är nog ett lite svårt område. Svindyra Innolite finns ju men alufälgar som inte är tillverkade i Asien. Finns det?
Däck var ju en liten soppa. Om nu allt från Panaracer tillverkas i Japan så får väl det betraktas som helt ok.
Cykelrelaterad elektronik lär nog inte bli lätt heller.
Efter att ha läst inläggen i den här tråden så känns det som att många anser att saker tillverkade i Asien (särskilt Sydostasien) inte är kompatibelt med schysst tillverkning. Känns som en grov förenkling och något som drar alla tillverkare med tillverkning där över en kam, trots att det säkerligen finns exempel på företag som tillverkar i Asien och försöker att bedriva sin verksamhet på ett hållbart och ansvarsfullt sätt.
Om kontentan i den här tråden är att man ska sluta köpa asiatiskt om man vill köpa schysst tillverkade prylar så ser jag inte värdet med den - jag tror inte att taiwaneser eller indoneser (för att ta två exempel) skulle ha det bättre om vi slutade konsumera cykelprylar tillverkade där. Det intressanta torde vara vilka tillverkare som tillverkar i låglöneländer som föregår med gott exempel och bidrar till en förbättrad levnadsstandard för sina anställda, leverantörer etc. och kan ha en positiv inverkan på de samhällen de är aktiva inom.
Alla fattar redan att det är komplext. Alla förstår att det är oerhört svårt att få till en ”perfekt” produktionskedja. Detta påpekades redan i första inlägget. Vissa människor fastnar i att det är svårt och ger upp där. Andra funderar på om det kanske finns några insatser i rätt riktning som är värda att premieras.
Jag tror bara att folk börjat med att plocka den lågt hängande frukten.
Det är liksom enklare att tänka sig att paul components lilla verkstad i californien man ser på instagram har sjystha arbetsförhållanden än den namnlösa jättefabriken i taiwan man aldrig ser
Ingrid tillverkar allt i Italien skriver de
Finns ju fler anledningar till att man helst köper saker tillverkat i en västlig demokrati. Köper helst lokalproducerat. Tyvärr så faller inte Skeppshult mig i smaken. Men kan man köpa en ny Skeppshult för 7500, så borde dom kunna bygga trevliga stålramar som kostar under 10"
Om man tror att det blir bättre för att man handlar med pissländer, så undrar jag när oljediktaturerna ska bli demokratier? Dom har ju haft några år på sig. Och Kina borde ju demokratiseras på ett halvår.
Taiwan är dock en fullvärdig demokrati numera. Men det är ändå långt bort.
Lite off tipic. Min son behöver nya löparskor. Finns det nåt märke öht som ligger på den positiva sidan?
Uppdaterar listan under dagen.
Stalle
Bra! Skaka fram den listan då. Tack på förhand.
Eller så försöker vi tillsammans här. Schwalbe ovan nämnt verkar ju vara positivt.
  • Gilla
Reactions: PJF
Min poäng är att du mer eller mindre diskvalificerat företag som tillverkar saker i låglöneländer i det allra första inlägget, oavsett om de gör det på ett schysst sätt eller inte, och jag tycker det är en felaktig premiss. Att bara lista västerländska tillverkare är ingen svårighet.
Det finns ganska många tillverkare av cykelkläder som har en miljö- och/eller en social profil här är bara några av dem:
Lite bakvänt att handla det från Nya Zeeland kanske :)
Tja, jag är inte helt säker på det. Transporten är inte miljöfin men det finns nog inget material som slår ull i miljövänlighet. Transporten är ofta en liten del i det stora hela (dock har jag ingen koll på textilier) och det är ingen större skillnad om ullen kommer som garn eller som färdiga kläder.
Håller med om att diskussionen lite väl mycket halkade in på att produkter från "höglöneländer" är bra, men produkter från s k låglöneländer (här främst "asiatiska") mindre bra.
Men låt oss återknyta till Stalles kriterie "number one" i TS som ju de facto är:
- Fairtrade (eller motsvarande).
Och då handlar det ju främst om "sjyssta" villkor i just låglöneländer.
Så allt väl...
Dock är Fairtrade främst inriktat på mer eller mindre ätbara produkter - kaffe, choklad etc etc etc etc...men även t ex f**bollar också ?
Så för cykelprylar får vi nog mest fokusera på att hitta något "motsvarande" (till Fairtrade).
Och kan ju vara en bra början att fokusera på främst "good enough" arbetsvillkor (att göra all in även på miljö, demokrati, kulturella strukturer etc blir ju än mer - låt säga "komplext").
Bra med denna intressanta diskussion !
Går att applicera på fler saker, fairphone gör fairtrade certifierade telefoner. (Som även utgör sig för att vara otroligt lätta att reparera och dem säljer reservdelar till) borde absolut gå att göra samma sak för cykelprylar.
KAN VI SLUTA ATT VARA BROR DUKTIG OCH GÅ TILLBAKA TILL TRÅDENS SYFTE.
Det jag tycker är svårt med produkter tillverkade i Asien är att det är svårt att hålla reda på är vilket land tillverkaren håller till i.
Hur tar jag reda på var X produkt är tillverkad om det inte exempelvis står "Made in the UK" på lådan?
Hur vet jag åt X alla produkter är tillverkade i Taiwan och inte i Kina? Vissa tillverkare tycks producera en del saker i Taiwan och and andra enklare och billigare komponenter i Kina eller andra länder med kassa arbetslagar.
Shimano är ju ett exempel på detta.
En intressant artikel från Cane Creek om tillverkning i Taiwan.
Jag tror vi håller på att ta reda på vad syftet egentligen är. Kriterierna kanske måste uppdateras efter Stalles initiala fråga då vi kollektivt lär oss mer allteftersom.
Diskussionerna i kommentarsektionen till denna artikel tycker jag är intressanta, där bland annat Sacki (mannen bakom BikeYoke) skriver lite om hans syn på att tillverka i Taiwan.
trådens fråga är intressant men vansklig. tillverkas plagget/lampan/cykeln/däcket på anläggning som behandlar sina anställda lite bättre, kommer ändå råvaror och komponenter med sannolikhet från platser där förhållandena är sämre.
slutar vi handla just därifrån; med viss sannolikhet ännu sämre.
varje välordnat land jag känner till har tagit sig från sämre till bättre just genom att öka handel och intäkter, inte minska dem. vi kan se hur platser som sverige, japan, hong kong eller taiwan tagit sig ur en fattig situation just på det sättet. att förhållandena blivit bättre för arbetare från dessa platser har knappast att göra med att samvetsgranna köpare på bättre platser vänt dem ryggen. snarare har det varit en process som kunnat ske på plats i takt med att intäkter ökat.
vi hoppas som köpare stötta platser som gör detta bättre, men undandrar då sämre platser att nå samma framgång.
alltså vanskligt.
en separat framgångsfaktor för ett välordnat samhälle är tillgång även för fattiga till skola och gratis högre utbildning. en del länder inklusive usa och sverige går där på senare år åt fel håll.
Lupine belysning är väl handbyggda i Tyskland av tanter och farbröder med bra löner, humanistiska värderingar, och som samlar på dyra modelltåg och sjunger i kyrkokör på fritiden. Verkar ganska sjysst. (?) ?
Ja, det verkar ganska harmlöst. Allt som är cnc-fräst, dvs lamphus och fästen, görs dock i Taiwan. Ett Pico lamphus tar tex >60 min att fräsa. Trots att det nästan bara är en fräs som arbetar, är det ändå inte hållbart att göra inom EU. Dithän har vi kommit. VD:n Wolf kanske skulle gå en kurs i delegering? Varje gång jag frågat något på info@lupine.de så är det han som svarar.
Pinglor: Spurcycle kan väl också läggas till listan?
Om Lupine platsar borde väl även Supernova göra det?
lupine har ju en helyllestämpel, och jag uppskattar verkligen deras innovativa ådra. positivt är att wolf exponerar sig på ett trevligt sätt. frågar du i hans forum varför de dragit ner på halvljusets styrka i nya versionen av ax, stryks den dock sonika.
och de lär inte köpa sina led-ljuskällor från någon annan stans än asien?
hantverksmässig produktion kan man ju gärna stötta när det ger ett mervärde t ex designmässigt. men ineffektiv produktion som leder till en suboptimalt värmekänslig lampa som piko? mer tveksamt.
ändå skulle jag säga att få företag passar bättre på listan än lupine. visar på hur vanskligt detta är.
Alpkit är UK- tillverkat. Förmodar att barnarbete än så länge är förbjudet trots Brexit.
Altura cykelkläder brukade åtminstone sys i Manchester.
Fel tyvärr. Eller rätt till 30%. Flera fabriker i Kina. Reagerade direkt på ditt påstående då jag själv ser Alpkit som ett typiskt lågprismärke med produktion i utlandet.
Ännu ett bevis på hur svårt detta är.
Görs inte Continentals finare däck, tex gp5000 et al i tyskland? Finns en trevlig pr-bild med ett gäng bastanta medelålders "babushkor" i läderförkläden framför gjutmaskinerna. Inga spinkiga thailändskor eller vietnameser så långt ögat når!
De har väl Osram som leverantör av LED-källorna om jag inte minns fel (åtminstone vissa modeller) och här finns lite skrivet om Osram:
Och väldigt mycket av Osrams LED tillverkas i Kina. I princip alla Osram LED jag har står det ”Made in China” på, en enkel googling ger också massor av info kring det.
Men, som stort företag har de förhoppningsvis resurserna att lägga på att säkerställa att deras produktion är miljömässigt och socialt hållbar flera led bakåt i kedjan, något som är betydligt svårare för små garageföretag.
Status
