Chrillepille skrev:
> Finns SRAM X9 i svart eller har de gjort den gamla
> fulingen ---> bakväxeln är det finaste på cykeln.
Det är den gamla fulingen då det är ett X.7 reglage. Hade hellre sett en Fox DHX Coil som bakdämp och skräpkomponenter på växlarna. Men den ekonomin är liiite svår att få ihop. ;)
Hela specen från Specialized websida:
FRAME All new BigHit FSR, 6061 ORE TT/DT, full cartridge bearing, ISCG mount, asymetrical rear triangle, 26" F/R wheel, adjustable geometry
REAR SHOCK Fox Vanilla R coil, 8.75x2.5", 190mm travel
FORK Marzocchi Drop-Off Triple, 170mm travel, air assist, rebound adjustment, double clamp, 20mm thru axle
HEADSET 1 1/8" threadless, OS Cro-Mo cups
STEM Truvativ Hussefelt, forged/CNC stem, 5 degree x 40mm, 31.8 clamp, black
HANDLEBARS Specialized Demo rise bar, 6061 alloy, 31.8mm, 6 degree upsweep, 9 degree backsweep
GRIPS Specialized MTB grip, natural/black
FRONT BRAKE Avid Juicy 5, hydraulic disc brake 8" Polygon rotor
REAR BRAKE Avid Juicy 5, hydraulic disc with 8" Polygon rotor
BRAKE LEVERS Avid Juicy 5
FRONT DERAILLEUR None
REAR DERAILLEUR SRAM X-9, micro cage
SHIFT LEVERS SRAM X-7 Trigger, 9-speed
CASSETTE Shimano HG50, 9-speed, 11-34t
CHAIN SRAM PC-971 with Power Link
CRANKSET Truvativ Hussefelt, 170mm with Truvativ chain guide
CHAINRINGS 34T, 4 bolt, compact 104mm pattern
BOTTOM BRACKET Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
PEDALS Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
RIMS Sun Single Track SL-1, 36 hole, 26" F/R, schraeder valve
FRONT HUB Specialized disc, 36 hole, 20mm thru axle
REAR HUB Specialized disc, 36 hole, bolt on axle, 135mm spacing
SPOKES 2.0mm (14g) stainless, black, brass nipples
FRONT TIRE Specialized Chunder 26x2.3" 60TPI, 2 ply, soft compound
REAR TIRE Specialized Chunder 26x2.3" 60TPI, 2 ply, soft compound
TUBES Specialized 26x2.4" schraeder valve
SADDLE Specialized freeride, 8mm steel rails, with X-Brace
SEAT POST Alloy micro adjust, 30.9
SEAT BINDER 7050 hard annodized alloy collar with QR, 34.9mm clamp ID, black
NOTES Chain stay/seat stay protector, derailleur protector, reflectors, owners manual
