Garmin Edge 1030
Garmin Edge 1030
Nu har Garmin släppt en ny betaFW 9.68, med en hel del nytt jmf med den den tidigare FW, 9.50
Changes made from version 9.50 to 9.68:
◦  Segments:
       Fixed issue with detecting segments that were going in the opposite direction of travel
       Improved segment and ClimbPro UI cooperation
       Fixed issues when approaching a segment embedded in a course and
            other minor segment UI issues
       Fixed issue where segment virtual partners would claim to be finished
            almost immediately after starting the segment
◦  ClimbPro:
       Improved estimated time to end of a ClimbPro climb
       Fixed ClimbPro page graph drawing
       Fixed issue where disabling 'Pop-up on Climb Approach' would disable ClimbPro completely
◦  Improved iPhone pairing
◦  Improved sensor connectivity
◦  Improved automatic FTP detection
◦  Added Go Back, Pause, and Go Forward workout step controls to the workout tray
◦  Added support for new GPS firmware. Sync your device to update to the new firmware
◦  Added option to delete a data field in quick edit mode.
        Access by pressing and holding a data field on a timer page.
◦  Improved grit and flow consistency between Garmin products
◦  Improved bike light connection stability
◦  Fixed bike alarm not turning off after correct password was entered
◦  Fixed radar vehicle drawing temporarily not updating
◦  Added a shortcut to the display menu by pressing and holding the
        Auto Brightness button on the status widget
◦  Added a toggle for MTB map theme
◦  Improved MTB trail search UI
◦  Fixed issue where history line wasn't updated while panning in the map
◦  Fixed issue with the number of power zones displayed post ride
◦  Fixed dual sided power meter calibration factor reporting only one side
◦  Fixed Firstbeat metrics for multiple rides during the same power cycle
◦  Fixed Training Effect UI layout
◦  Removed unnecessary beeps for notifications that don't need them
◦  Fixed timezone map downloads from WiFi
◦  Fixed issue with power targets in TCX workouts
◦  Made various device stability improvements
Läs mer här: https://forums.garmin.com/sports-fi.../new-edge-1030-public-beta-9-68-now-available
Garmin Edge 1030
Blue halo of doom...
Är detta något ni känner igen?Kanten av skärmen blir svagt blå. Tydligast dagtid i solljus. Fn mer kosmetiskt än ett problem.
Är det en process som
kommer att tillta?
Har kontaktat Garmin Sverige men de förefaller ha annat för sig än att svara på mail. (leta bitcoins kanske...)
Garmin Edge 1030
Har samma problem med min. Garmin har erbjudit sig att byta ut den, tror jag tänker göra det men då de inte vill skicka en utbytesenhet i förväg (helt ok) så får det vänta till efter sommaren.
Garmin Edge 1030
Nu har Garmin släppt en ny FW 10.00, med en hel del nytt jmf med den den tidigare FW, 9.50
Changes made from version 9.50 to 10.00:
◦ Segments
  -Fixed issue with detecting segments that were going in the opposite direction of travel
  -Improved segment and ClimbPro UI cooperation
  -Fixed issues when approaching a segment embedded in a course and other minor segment UI issues
  -Fixed issue where segment virtual partners would claim to be finished almost immediately
◦ ClimbPro
  -Improved estimated time to end of a ClimbPro climb
  -Fixed ClimbPro page graph drawing
  -Fixed issue where disabling "Pop-up on Climb Approach" would disable ClimbPro completely
Läs mer här: https://forums.garmin.com/sports-fi...ge-1030-bontrager-version-10-00-now-available
Enl den sidan verkar det vara en gradvis "utrullning" av uppdateringen
Garmin Edge 1030
Förbaskat också, min google-fu är helt ur synk!
Hur gör jag för att automatiskt ladda upp filer från enheten till google drive eller liknande? Strava är bra osv men jag vill leka själv.
Vad jag vill är att få Garmin connect eller annan app att synka mina spår till min egen lagring, det kan vara Google drive eller Synology nas. Helst, om jag får drömma alltså, ska det gå sömlöst eller åtminstone med så lite trixande som möjligt, åtminstone i det dagliga användandet.
När jag googlar får jag bara svar på hur jag laddar till enheten...
Garmin Edge 1030
För att göra det via app:en eller webb-sidan så tror jag att man måste använda Garmins API:er för att göra detta, och de tillåter bara utvalda samarbetpartners att göra det. Finns någon som försökt att hacka sig runt det men verkar inte fungera längre:
Om du kan tänka dig att koppla in enheten via usb i din dator för att göra detta så borde du kunna sätta upp det med FreeFileSync:
Det är inte heller inte så svårt att bara kopiera filerna från enheten in till valfri lagrings-plats, så gör jag för backup. Men det orkar jag inte göra efter varje runda.
Garmin Edge 1030
+1, brukar köra batchvis, en gång i månaden kanske.
Det hade varit kul om det i Garmin Connect applikationen gick att överföra trådlöst till datorn.
Garmin Edge 1030
tjena!
Hur i hela friden får man enheten att läsa kartor och rutter från SD-kortet? Jag lägger kartor i custommaps på sd-kortet, men de syns inte i enheten. Hittar inget när jag googlar heller.
finns det en manual jag kan följa så länka gärna till den, det är omöjligt att hitta för mig.
håhåjaja!
//Kaj
Garmin Edge 1030
tjena!
håhåjaja!
//Kaj
Kartor ska väll alltid ligga i mappen garmin, både på enheten och sd-kortet.
Garmin Edge 1030
Okej! Rutter då? Jag borde kunna lägga fit-rutter i Courses på sd-kortet istället för på enheten, men den läser dem inte när jag gör det idag.
De kartor jag använder nu är .kmz och kml, spelar det någon roll? Måste jag konvertera till .img?
Garmin Edge 1030
Nu har Garmin, efter några betaFW, släppt FW 11.00, med en hel del nytt jmf med den den tidigare FW, 10.20
Changes made from version 10.20 to 11.00:
◦  CIQ:
    -Added CIQ 3.2 support.
    -Added encryption for CIQ widgets and data fields.
    -Added CIQ data field alerts.
    -Added BLE sync support for the Connect IQ app.
    -Added CIQ workout information support.
◦  Indoor Training:
    -Added smart trainer widget that includes Tacx Road Feel controls.
    -Fixed issues with grade, power, and resistance controls for smart trainers.
    -Fixed course points for indoor trainer rides.
    -Added the Virtual Partner to the map page when following course or activity on indoor trainer.
    -Fixed lap banner bug on trainer grade control page.
    -Improved indoor trainer workout UX.
◦  Simple Setup:
    -Added Simple Setup support. Port old activity profiles and sensors from Garmin Connect
       during initial setup.
◦  Livetrack:
    -Added device driven Livetrack.
    -Added course sharing.
◦  FTP:
    -Improved reliability of FTP auto detection.
    -Added tone to end of FTP test to notify user of completion.
    -Fixed FTP test workout preview page.
◦  Fixed crash when updating sensor software.
◦  Fixed issue with smart eat and drink alert prompts.
◦  Fixed segment completion bugs.
◦  Fixed bug in Intensity Factor calculation.
◦  Fixed retaining light network disable over power cycle.
◦  Added instructions for pairing a radar in the radar sensor search menu.
◦  Fixed other minor UI bugs and crashes.
Läs mer här: https://forums.garmin.com/sports-fi...ge-1030-bontrager-version-11-00-now-available
Enl den sidan verkar det även denna gång vara en gradvis "utrullning" av uppdateringen
Garmin Edge 1030
Garmin Edge 1030
Måste berömma Garmin återigen för garantiåtaganden i världsklass.
Min 1030 som jag fått istället för min Edge 1000 som jag köpte från England för länge sedan har hängt sig och slutat visa kadens/effekt ett 10-tal gånger för att slutligen hänga sig helt.
Efter div korrespondens med Garmin support kom det idag en Edge 1030 plus bundle i brevlådan.
Bra kundvård❤
Garmin Edge 1030
Denna från Garmin använde jag mellan mina pinnar. Valfritt höger eller vänster pinne.
    424.7 KB · Besök: 186
Garmin Edge 1030
Edge 1030 Plus:
Någon mer som har samma problem med att det inte går att avbryta att larmmedeland går iväg till säkerhetskontakten vid en krasch?
Anledningen är att fönstret med kartbilden tar fokus så fort man stannar med cykeln oavsett vilket fönster som man har aktivt innan kraschen.
Eller snarare sagt, fönstret med möjlighet att avbryta larmet är där i någon sekund innan kartbildsföstret tar fokus
Garmin Edge 1030
Inga problem att fråga i den här tråden, men det finns en Garmin Edge 1030 Plus-tråd
Om det finns kraschmeddelande i gamla 1030 vet jag inte, efter att 530/830 hade lanserats fick även 1030 en del av de nya funktionerna hos dem med SW/FW-uppgraderingar,
men om även kraschmeddelande ingår där vet jag inte. Det kanske är HW-beroende?
I vilket fall när jag kraschade för ett par veckor sedan tolkade min Edge 1030 det som ett hopp!
Cykeln klarade sig, men jag har fortfarande ont i revbenen och kan bara sova på ena sidan! Men det kunde ha gått värre, mkt värre
Garmin Edge 1030
Edge 1030 Plus:
tror det måste gå en viss tid innan larmet går. Avbryter man inom den tidsramen så ska det gå. Annars går det nog iväg. Eller menar du att det inte fungerar att avbryta även inom denna tidsram?
(har aldrig provat detta så vet inget mer än så)
Garmin Edge 1030
Edge 1030 Plus:
Nu har jag ingen 1030 Plus och inte heller just det problemet, men däremot en 530. Ibland när jag stannar så växlar den vy till Trailforks. Det kan inte vara så att du kan växla vy med swipe eller hur man nu gör på 1030 Plus och därmed nå avbrytknappen?
Garmin Edge 1030
Edge 1030 Plus:
Tack för snabba svar.
Som Sambal säger så går det en viss tid innan meddelandet till säkerhetskontakten skickas iväg. Jag skulle tro ca 10-15 sekunder. Tanken är att man under den tiden ska kunna avbryta så att meddelandet inte skickas. De görs genom att det automatiskt visas en föster/inteface med valet att avbryta att meddelandet skickas. Så långt fungerar allt bra. Broblemet är att fönstret med kartan visas med automatik efter ca 3 sekunder och därifrån hittar jag inget sätt att komma tillbaka till fönstret där man kan avbryta att meddelandet skickas. Jag has swipat och klickat på krysset som finns i kartfönstret men fönstret för att avbryta att meddelandet skickas kommer inte tillbaka.
Jag lyckas inte hitta någon funtion där man kan stänga av att fönstret med automatik visas så fort man stannar annat än att helt ta bort kart funktionen. Men då kan man inte se kartan över huvud taget och det är ju lite av hela grejen med 1030
Garmin Edge 1030
Nu har Garmin, efter några betaFW, släppt FW 12.00, med en hel del nytt jmf med den den tidigare FW, 11.10
Changes made from version 11.10 to 12.00:
◦ Course Routing
  - Improved course routing speed.
  - Added automatic course route caching.
◦ Map
  - Improved map visibility and contrast with new map themes.
  - Added a popularity layer to highlight roads that Garmin users have ridden
     the most.
  - Added directional arrows to routes, courses, and history lines.
◦ Phone
  - Added smart syncing before an activity.
  - Added a Sync Now button to the settings widget and the
      Connected Features > Phone menu.
◦ Updated Firstbeat library for various improvements and bug fixes including
    a fix for training stats being reset on a multiple day activity.
◦ CIQ
  - Fixed issue with BLE sensors in CIQ data fields after waking the Edge from
     sleep mode.
  - Fixed issue where activity controls would not work in a CIQ app.
  - Improved CIQ data field settings experience by always prompting when
      adding a settings-capable CIQ data field.
  - Increased font size for app background messages.
  - Fixed other minor issues.
◦ Fixed several inReach issues.
◦ Improved Garmin dual-mode sensor management.
◦ Improved power meter calibration and software updates.
◦ Improved the cycling dynamics page.
◦ Increased maximum number of workout steps from 50 to 100.
◦ Combined the indoor trainer Target Power and Resistance data fields into
    a single  new "Trainer Mode Value" data field that will dynamically change
    the title and value based on the current trainer mode between Target Power,
    Slope, and Resistance options.
◦ Added support for including metabolic calories in the total calories reported in
   the calories data field and recorded in the activity file.
◦ Fixed manual elevation calibration.
◦ Fixed issue with blank Strava segments appearing on the Segment Explore widget.
◦ Fixed minor bugs.
◦ Improved device stability.
Läs mer här: https://forums.garmin.com/sports-fi...ge-1030-bontrager-version-12-00-now-available
Garmin Edge 1030
De nya kartalternativen är kanske bra men inget för mig. Allt av färger och info om terräng försvinner, även på Friluftskartan. Fick ställa om alla mina profiler då Garmin valt att ändra till det nya (suck!). Väljer Classic (activity profiles - nnn - navigation - map - map theme) för att få som det var förrut.
Garmin Edge 1030
Visa bilaga 496411
Tack.
Min har hängt sig tre gånger i kväll redan. Perfekt inför ST.
Garmin Edge 1030
Den här hör ju hemma i flera trådar kanske
In Garmin’s own words, the update provides:
New clean, high contrast maps that make bike-friendly road, gravel, or mountain routes more visible in all light conditions.
A Trendline popularity heatmap based on billions of miles of uploaded ride data now layered directly onto the map and adjusts automatically based on ride type so cyclists can instantly see the most relevant places to ride.
Faster route calculation speeds, allowing cyclists to start riding more quickly. Now, after a route has been calculated once, it’s cached so cyclists can get started in seconds.
Garmin Edge 1030
Köpte en beg 1030 av en vän som precis fått den utbytt av Garmin, så den är väl refurbished. När den startar ser display ofta ut såhär:
Har uppdaterat den till senaste mjukvaran (12.20), men problemet fortsätter.
Någon som haft detta problem?
Garmin Edge 1030
Jag chansade och köpte en beggad Edge 1000 på Ebay, från UK. Säljaren blånekade till att ha känt till felet med minneskort (vilket såklart kan stämma). Testade istället att få hjälp av Garmins support, jag var givetvis öppen med att det var begagnat, och det slutade med en ny 1030 efter att jag styrkte mig Ebayköp.
Om ni nu undrar varför era nya Garminprylar är så dyra ?
Garmin Edge 1030
Har liknande erferenheter av Garmins mycket generösa och proffsiga kundtjänst.
Köpte iofs nytt från dem till att börja med, men erbjudits nya (bättre) versioner med mycket kraftig rabatt när skärmar spruckit, armband gått av, pulsband delat dig, usb-porten dött etc. För att hårddra det kan man säga att forfarande lever på de Edge 305 och Forerunner 405 som jag köpte för 15 år sedan och bara behövt slanta ut en bråkdel (50-70% av nypris) för att uppgradera med jämna mellanrum.
Garmin Edge 1030
Låter ju som att ni satt det i spel att utnyttja deras generösa garantier.
Förstår inte heller hur det kan vara så mycket problem, min 1030 fungerar fantastiskt bra, bättre än ny för över 2+ års sedan med uppdaterad firmware
