jonte987
Garmin connect imponerar inte
Det är nog det mest sannolika efter en snabb Google. Och att du ska ha bara alpha numeric i password.Ok, ska testa g och n endast med. Mitt 2,4-nät är bara oanvänt skräp oavsett, dess enda existensberättigande är ifall jag får klockan att lira med det ?
- Verify that your Garmin watch and your mobile phone (or another device) connect to the same Wi-Fi network
- Make sure the WiFi network you want to connect to supports 2.4 GHz frequency AND the 802.11g wireless standard–the 802.11n standard is backward compatible and supports 802.11g devices. However, some readers discovered they needed to set-up an 802.11g 2.4GHz Wireless LAN Access Point for their Garmin devices WiFi to work! You can also change your router’s transmission mode to 802.11g via the router’s admin settings
