Dagens bild
Lotta B
Dagens bild
Hittade ingen sån här tråd i elcykelforumet så tänkte det var dags. Tog en kort och suverän julaftonscykling, härligt!?
Dagens bild
Ine need some rules…
Bike uprigght
From the drive side
Crank forward and parallel to the ground
Tires lined up with brand in top
Dropper post extended
In the lowest gear
Only kidding. However points will be deducted for violating above rules!
Dagens bild
Bike uprigght
From the drive side
In the lowest gear
Yeah yeah... :D I found it a little entertaining to break almost all of them...yes I'm childish in some ways... Bike lying down, yes that hurt a little but hey.. ;)
Dagens bild
100% Brixter gloves
Great until about -7C (ish) for me (once I get a little warmed up and as long as I stay in the woods (on open road it is an all different bargain)
Hm, interesting, thanks! I've been thinking about going the route of motorcycle gloves as I find the bike ones...not that good. I'd like the dexterity of the type of gloves in that link, been thinking of Hestra winter pro but then it looks like a clumsy work glove.
No, I go for keeping the temperature in the woods, the transport on asphalt was...unpleasant. Today I use a pair of old pearl izumi shell gloves with merino liners, they usually keep me warm but at -10 they didn't keep my hands limber enough even when active at techy trails.
Dagens bild
Jag kör väldigt tunna löparhandskar eller finger vantar som ett inre lager och sedan en rejälare vante över.
Tyvärr verkar det som polar plug projektet gått i graven. Kanske något som en annan vill ta vid. Inte direkt komplicerat.
Dagens bild
Mm, liners + handskar har funkat bäst för mig hittills. Vill ha smidiga handskar så att det går att modulera bromsar etc, gillar inte när det inte är bra kontakt med händerna.
Aha, det låter som en enkel grej med polar plug, hoppas nån styr upp det.
Dagens bild
I have used those in the past on my fat bike (I don't have it anymore since I no longer go to Darlana during the winter) and I have moved them to my kickbike (fat tires and two Siberian husky as drivetrain)
They are fine (other than look really not gnarly ;)), with plenty of room for the fingers and brakes, but they are "almost" too hot unless it is below -15C)
If you don't mind the look. they are a good option
Note that since they come with their own bar end plugs (that you need to use), you cannot use grips with integrated bar ends and need to use double clamps grips like those ones
Dagens bild
No not the gnarliest of looks if that's important :D But I bought the cheapish Hestra work gloves I posted above, they did the trick today, puh. -10 and even my indexfingers were kind of toasty. Not that cumbersome and clumsy in my size, I'll look some more at those 100% Brisker gloves when the spring comes thou. They remind me of the Fox gloves I wear otherwise.
Dagens bild
Not “gnarly” is in fact the understatement of the century and we are barely a 1/4 in
    783.1 KB · Besök: 142
Dagens bild
Hur upplever du sq-lab sadeln?
Väldigt nöjd med sqlab överlag efter att ha sökt den rätta sadeln i åratal så har jag nu 3st sqlab denna 60x, en 611 på en mtb samt en 612 på graveln. Denna kör jag också med på fatbiken vintertid. Var lite skeptisk först när jag köpte 611an men efter en tid med justerande så klarade jag 2-3t utan bekymmer. 60x är mjukare och bättre när man sitter mer, använder den också på fatbiken. Lite breda kanske enligt deras mått så ta en modell smalare en rekomenderat speciellt om du har stoppning i byxan.
Dagens bild
Faktist nöjd med funktionen mot kvistar o dylikt som brukar ha tendes att bromsa eller piska på fingrarna? Tänkte nog montera bort de först för de var monterade vid köp men gav de en chans och tror de få sitta kvar tillsvidare.
Tack, gott att veta. Funderar på ett par av de anledningarna samt om de kan skydda fingrarna mot vinterkyla. Det blir nog ett par inom kort :)
Dagens bild
Tack! Har själv sq-labs handtag och inner-barends på min cykel och är väldigt nöjd med dem. Kanske får bli en sadel också, om man bara kan klura ut vilken bredd man behöver.
Dagens bild
Mät bredd mellan sittben finns anvisningar på sqlabs hemsida eller googla hur du gör. Tyckte själv det var klara anvisningar och lätt att hitta rätt modell sedan så såg jag flera som rekomenderade en modell smalare på nätet?
Dagens bild
Veckans normala underhåll klart inför en ny vecka med pendling till kontoret samt lite sköna grusvägar och bättre stigar på kvällarna och till helgen. Lilla tokiga hunden får åka med i hundkorg fram ibland också.
Canyon Roadlite :ON med Fazua motor/batteri/elektronik. Toknöjd hittils, inköpt i mars/april.
    803.9 KB · Besök: 64
