Jag sprang på en tråd på mtbr som verkar beröra just detta, bl.a.:
”…the dpx2… …is definitely not working on any occam, and that's comfirmed by the techs at Fox…”
”the dpx2 on the occam is always in the wrong part of the travel: too much air and too high in the travel, packing the back end, very stiff feeling (especially with the frame design), and drop some psi, now way too soft, too much travel used, where the shock can't keep up with the hits (stiff feeling once again..)”
”It's a poor shock, you can't separate the compression from the rebound circuits due to the design. Even the float DPS is better in this respect…”
Will a, say, Fox DHX2 coil shock fit into the frame on a m10/m30? Does anyone know?
www.mtbr.com
Tänkte det kunde vara intressant läsning. Hittade den när jag letade efter svar på om det går att länga slaget på DPS från 50 till 55 mm.
